It is currently Sat Aug 02, 2025 5:13 pm
 Post subject: Ukulele dimension
PostPosted: Tue Nov 25, 2008 1:25 am
I am starting a build of a standard (soprano) uke, as a prelude to starting on a classical, based on Cumpiano et al.
I have assembled timbers, as well as tracings off a uke from a local builder, and have harvested dimensions from this site.
The one I neglected to note, is the thickness of the neck. I have figures for the width of fb at 12th and at nut, but it is the thickness, between the heel and the headstock that I require.
Any offers??
regards
Alastair
 Post subject: Re: Ukulele dimension
PostPosted: Tue Nov 25, 2008 1:48 am
Alastair I suggest you get in touch with the uketalk.com forum. You will find many uke builders there. Also consider buying a plan from Hanalima, Stewmac or LMI.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Nov 26, 2008 6:39 pm
Thanks for that, I'll give them a try,
regards
PostPosted: Thu Nov 27, 2008 12:54 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
Here is some old plan.
Might be usefull
http://www.nalu-music.com/nalu/Plans1915.pdf
Mine is a tenor and it is 19 mm at the nut and 25 at the 9nth fret ( 12 fret to the body)
This is with the fingerboard
You do not need to make it too thin as it is very narrow.
Just carve it and try it!
Good luck
Users browsing this forum: DanSavage and 36 guests
